Antenna 3G/4G LTE Gellan FullBand-15M BOX
Transmitting and receiving MiMo antenna GELLAN FullBand-15M BOX is designed to organize data transmission via 3G technologies (2100МГц) and 4G LTE (1800/2600mhz). The antenna provides a stable mobile Internet access. GELLAN FullBand-15 significantly improves data transfer rate and ensures a stable connection with the base station of the cellular operator at a distance of 10 kilometers.
The range of frequencies ,1700-2700МГц
3G (UMTS2100) 4G (WIMAX,LTE1800, LTE2600)
Gain,dBi  12 15dBi...
Input impedance, Ohm  50
The CWS in the operating range  <1.5
Antenna polarization  vertical/horizontal
Connector type  2 x SMA-male
Cable  7 meters UTP->USB
Overall dimensions, mm  240 x 240 x 95
Weight, kg  1.25
,,,,and yet I do not see bandwidth of 1700 ---- 2600MHz...???!!!
,,,but of course, the antenna has a circular polarization....!!!!
