Compact panel 3G (honest 14dBi, VSWR<1.4)
by Vodkaman user...
"Useful this thing or not, you decide, but I was curious to Tinker. The basis is the biggest RK 240x195mm. Material - galvanized, 0.5 mm copper wire 1.5 mm. Box (cover) only such other firm requires recalculation."
Achievement practice ..?????
PQ1sf.pdf
Another achievement of Vman...
Poor polarization...
in the animation field, it is seen that the antenna is turned "paleoliticheskoi" polarization, the lower patch remains in phase from the top to the same.
in short, power is not good. it is necessary to draw a line at right angles to the edge of the patch, and not to the line between the patch and screen.
