AX-2020P 3G panel antenna (20 dBi)
Electrical characteristics
Operating frequency range, MHz 1900÷2180
Gain, dBi 19-20
The width of the days in H-plane, degrees 16÷18
Days width in E-plane, degrees 16÷18
The sidelobe level, dB, not more -13
The ratio of forward/back, dB 24
Input impedance, Ohm 50
SWR in the frequency range, not more 1,5
Permissible power watts 10
Polarization vertical/horizontal/inclined
Weight with mount, g 3350
Overall dimensions without mounting, m 0,45х0,45х0,05
Connector N-female
Antenna material  steel, galvanized steel
Protective coating powder polymeric paint
Material of protective box ABS+polycarbonate
,,,yes, this panel antenna is very good and is broadband....!!!
