POWERLINK Outdoor Plus
Ultra Long Distance Indoor and Outdoor WLAN Wireless USB Adapter
1W High Power 28dBm w/Hi-Gain 14dBi Patch/Panel Antenna
Improving 12X Signal Reception and Distance and 6xSpeed
 Specification :
Model Name Outdoor Plus
ChipsetRalink RT3070
Standard IEEE 802.11b, IEEE 802.11g (WIFi Compatible), 802.11n
Frequency Band 2.412GHz ~ 2.484GHz unlicensed ISM band
Data Rate IEEE 802.11b: 1, 2, 5.5, 11Mbps   IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, 54Mbps 802.11n: up to 150Mbps
Output power 28±1.5dBm (1000 mw)
Power Consumption Transmit:<1000mA Receive:<600mA
Antenna
14 dBi directional panel antenna built-in
Operating RangeUp to 2000 meters (Depending on surrounding environment)
Security WEP (64/128/256bit), WPA, WPA-PSK,  WPA2 TKIP/AES, WPA2-PSK
Modulation 802.11b: BPSK,QPSK, CCK 802.11g: OFDM
I/O Interface USB2.0/1.1
Operating System Windows XP, SP2, Vista, 7, 8, MAC, Linux
Operating Temperature -20°C ~ +70°C
Storage Temperature -40°C ~ +80°C
Humidity 10 ~90% (non-condensing)
Channel 2412~2462 MHz (US) 11 channels,  2412~2472 MHz (EU) 13 channels  2412~2484 MHz (Japan) 14 channels
LED Link/Active
Certification FCC RoHS compliant
7 hours ago, Techd said:
do you have the measurement?
,,,,see this...
