A Simple Patch Antenna
116 posts in this topic
", first  move it down, and then resize the reflector ...!!!
But I think it would be better 110x120x30mm
I don't think so, let's see...!!!
yah,10dBi...
hey, i'm just wondering what would be the gain that i made? assuming that the patch placed in the middle..
,,, the gain is the same but a better focus results...!!!
But, I think the best solution is this...
same dimensions?
9 hours ago, Eric said:
what are the dimensions?
I need a help , how can we calculate the width of power divider as feeding network.
9482979.pdf
its okay to solder that part?
Edited by Eric
On 01/06/2019 at 10:44 AM, Admin said:
Yes, that's the best one...
simplepatch1.cst
Hi, I do not have CST but would like the dimensions if possible please? Maybe you can upload the model file in solidworks or step?
23 hours ago, Admin said:
Hi, I will be putting this antenna in a circular enclosure so it can rotate for direction. Is there any impact to putting a circular reflector behind it? (It centres on the main element)
Also, your last design has dual feeds and I am unsure how to wire-up :$. The attached is your single feed version with the backing reflector.
simplepatch.IGS
