A Simple Patch Antenna
116 posts in this topic
you can make a sub-reflector with these  dimensions(approx)...
Yes, this makes good sense but the container cannot be that big so I will stick with your single feed design, thankyou for you great advice :D
On 16/04/2019 at 9:55 PM, Admin said:
How well do you think this compares against your Dual Band Cantenna?
I only just found your cantenna design and I love the fact that it does both frequencies.... and it's small!!!
,,,, one is a waveguide the other is a patch antenna, they differ from each other ... !!!
Yes but performance is very similar and you have managed to get Dual frequency from the cantenna
On 12/12/2017 at 1:43 PM, Admin said:
Pokoknya antena saya lebih bagus...!!!!
regards, admin, consul, I use tp link wr820n, 5volt power, less capture power wisp mode, if it spreads well, for example the antenna modif 1 to capture source / focus, what antenna model is the best, can strengthen the capture power of 1/2 bar to 3bar or 4 bar, plan to be interested in gun wifi antenna model, or something else, thank you
I took up the idea of a single patch with a rectangular reflector with inclined wings...
