UWB Antenna on PCB
A UWB antenna design requires broad bandwidth of 2-11 GHz and good omnidirectional radiations patterns.Among the proposed UWB antennas ,the printed monopole antenna (PMA) is very promising due to its remarkably small size and simple fabrication.
Hello sir, I need your help in designing the  similar SMA connector in HFSS. Please also mention how we can excite the antenna Using SMA connecotr. Thank you
i am unable to open the file format jomy. is it really necessary to excite the antenna with a sma connector ? isn't waveport excitation not enough ?
 No, it is not necessary, but must expandable patches, and then put only one port
,,,open  HFSS>Modeler>Import>sma.port
sma.port in my archiever...sma.zip
 Look, here"s you file in HFSS...!!!!
New Folder (2).zip
hello jomy....first of all sorry for the late reply, while opening the sent hfss file i am getting the below error, please help me....i am using hfss 15
i"m using hfss 15  too,I do not understand what is your problem
A novel rectangular microstrip patch antenna for ultrawideband(UWB) applications is proposed. The ultrawide frequency response is achieved by determining the dimensions of the radiating patch of antenna . Besides a directive radiation pattern, high efficiency and a constant gain is achieved in the operating bandwidth.
,,,you want to say...a conformal antenna is an antenna that conforms to something; in our case, it conforms to a prescribed shape. The shape can be some part of an airplane, high-speed train, or other vehicle. The purpose is to build the antenna so that it becomes integrated with the structure and does not cause extra drag
Hi jomy thanks for the reply, i want you to design similar to the below picture...a 4x4 conformal MIMO antenna
,,, yes, but I also need some dimensions...!!!!
