devton
helix antenna with second helix-reflector
Second helix not connected to reflector and may work just as passive reflector!
It may be not seen on picture, but it should be behind main helix (between main helix and reflector) in 0.25 wavelength from main helix.
Main thing here - just same helixes AND round wire in helix (not stripe).
Maybe you can simulate it with small amount of helix turn (3-4-5) ?
Edited by devton
words
And if the second helix is made from strip ...?
i think from same round wire as main to let traditional big reflector work as it should
it will work as in yagi antennas where reflector it is just same wire
let say so: on short helix antenna it's better be same round wire for reflector-helix
on long helix it may be stripe
aaa...ok,,, and the second helix it is in the air...!!1
yes in air i think....if connect second helix to reflector near place where first connected, it wiill be odd omnidirestional antenna with a lot of OHMs and asymmetrical diagram
Edited by devton
show from different angle
looks like IT but i can not understand how it looks in 3d
40 minutes ago, Admin said:
,,,like this....??
yes it is
maybe it took few tryes by moving it on X axis before it work well...
16 minutes ago, Admin said:
11dBi-3,5 turns
is it 15cm diametr round plate-reflector?
single 5 turn helix should be 10 dbi too 0_o?
