sandeepv
UWB antenna
126 posts in this topic
this is the vswr plot we require :).....they are not same please check  where minimum and maximum values of vswr occuring in both plots
,,,it"s ok,,,,but you have the primitive UWB antenna...!!!
Last question, Can I follow the steps which were used to implement the antennas mentioned in above-attached base papers ? .... with the knowledge I have in antenna design( of course it is low), I will design an antenna. thereafter can I go to the fabrication of the antenna or not?
,,,you can  go to the fabrication of the antenna but attention to the type of  PCB material ...!!!
thank you very much.....for your time and suggestions...
,,,a few animation...
hello, good afternoon... how can we plot peak gain vs frequency plot in HFSS for the above antenna.
For plotting the gain over frequency you need to make a frequency sweep and activate the "save field" option. Then you select under plot Far Fields Reports -> Rectangular plot. Now you can plot the gain versus the frequency.
or...Results/Create far field reports/Rectangular plot
i have calculated efficiency by taking the ratio of (realized gain/ directivity)*100 ...is that expression correct....because i got the efficiencies greater than  100%.
the below image shows the calculation procedure i did for efficiency
,,,put  a real function value on   Output Variable>Quantities>>>Function....(not "none")
sandeepv,,,,you can try and this....??
8 hours ago, sandeepv said:
is it correct simulation ?
sss.hfss
Now I'll try, but why do not you put the plug sma?
I am not happy with that SMA connector. can you attach the reference paper for the above antenna.
